Ricardo Paula Posted August 30, 2022 Posted August 30, 2022 Hello Mates. I recently bought an 8.8" sensor panel from Waveshare. It came with two themes, but when I put them on, they look like the pictures. I've tried themes that I saw here on the forum with 1920x480 but all are incorrect. If you can help please. Thanks in advance. Regards. Ricardo Quote
Awol Posted August 30, 2022 Posted August 30, 2022 Whats the resolution of the screen and what resolution do you have aida64 set at ? I have a Waveshare 11.9 inch ips screen 1480*320 so have set aida64 settings the same. Quote
Ricardo Paula Posted September 1, 2022 Author Posted September 1, 2022 On 8/30/2022 at 5:31 PM, Awol said: Whats the resolution of the screen and what resolution do you have aida64 set at ? I have a Waveshare 11.9 inch ips screen 1480*320 so have set aida64 settings the same. stay the same . I dont understand what is hapening The resolution is 1920X480. 1108443634_Semttulo.bmp Quote
Awol Posted September 1, 2022 Posted September 1, 2022 And your secondary display resolution is that set to the same as your screen size ? Quote
Ricardo Paula Posted September 3, 2022 Author Posted September 3, 2022 i cant resolve this. Its very frustanting, i see amazing themes here and i can put on mine. Please help me resolving this. Regards. Ricardo Quote
jsouth20 Posted September 3, 2022 Posted September 3, 2022 [Custom Scaling Factors] Happens when a template is created on a machine with different OS display ‘SCALING’ settings. In windows OS, it’s the (Custom Scaling) display setting. I had the same issued with my waveshare 8.8” at first, no matter which template I tried – they never fit right and were all out of alignment. I have 4k monitor and my Windows display setting is set to a [Custom Scaling] of 150%. So even if I import a template that matches my sensor panels resolution, Windows was still applying a 150% Scaling factor on top of that to my 2nd display. To fix, I had to change the way Aida64 opened in relation to DPI Scaling. That way my main Display#1, was left untouched, but now my waveshare 8.8” (Display#2) displays all templates with the correct scaling factors and everything fits as intended. 1 1 Quote
Ricardo Paula Posted September 4, 2022 Author Posted September 4, 2022 Problem resolved. Thank you very much for your help guys. Now i can enjoy my new sensor panel. Quote
