Xiaomi 12T Pro CPU Misidentified
shauno100
I have a Xiaomi 12T Pro and the CPU is being identified as a Snapdragon 8 Gen 1 SM8450 when my phone is meant to have a Snapdragon 8+ Gen 1 SM8475. Can this bug be fixed? Other apps are reporting correct CPU but was slightly concerned my CPU was in fact SM8450. Is the CPU detection obtained from the actual hardware or does the app pull the info from a database online after matching the model number?
Thank you for your feedback. We will fix the reported issue in the next AIDA64 app update.
