tastelesschimp Posted April 7, 2023 Posted April 7, 2023 I recently built a custom water cooling setup and am struggling a bit for configuring a sensor panel that will show me the pump speed for my Corsair XD7 Pump/Reservoir. I have enabled the Corsair boxes in the preferences in Aida 64 and I have the fan speed sensor connected to a Commander Pro. I also have 7 other fans in my PC, 6 of which are connected to a Commander Core XT thats part of my Corsair 5000T case and one additional one connected to another Commander Core XT. However, none of these fans appear in Aida 64, the only fans which appear in the Cooling Fans section are PCH, Chassis #2 (which is my Barrowch flow monitor), Power Supply, GPU, and GPU2 and in the Fan Speeds section it shows GPU and GPU2. My GPU is water cooled so I am not sure what sensors its actually pulling. Quote
tastelesschimp Posted April 16, 2023 Author Posted April 16, 2023 Based on searching other areas of the forum it appears that any fans connected to Commander Core XT's are not supported by Aida64 as the USB cannot be deciphered. However, I was unable to locate any information on the XD7 being monitored through a Commander Pro and if that is supported? Quote
tastelesschimp Posted May 1, 2023 Author Posted May 1, 2023 So no response on this one? Not even a confirmation that its not supported or a confirmation if you are working on supporting the XD7 for the future? Quote
tastelesschimp Posted June 17, 2023 Author Posted June 17, 2023 Is it pointless to continue to pay for Aida64 if this is the type of support I should expect where you won't even acknowledge this post and if the hardware is supported or planned to be supported? Quote
