I built a new PC. I have an LG 27" 850 monitor and a 7" sensor panel as well as a 34" ultrawide monitor...so 3 monitors in total.
My main panel is the LG. To the left is the 34" Gigabyte and the right inside the case is the sensor panel. All hooked to my strix 3070 GPU. The  sensor panel via HDMI, the 34" ultrawide gigabyte via HDMI and the 27" LG via DP.
The system is set to span the background under "windows personalize". The LG is set as "main panel" in "display settings"....
however....when the system wakes up from sleep mode, all my programs want to open up under my display panel (screen 3) instead of screen 1.
I'm a little lost on that aspect.  I have to close chrome or any other system program to get it to open up in screen 1.
Any insights??
have you set the 34" as the main display?
if your on windows 11, in system display there is an option to remember location based on screen.
screen shoot for you. hope it helps.
