72hundred Posted July 29, 2023 Posted July 29, 2023 Hi, For years I've been using the Logitech G19s with its built in LCD (320x240 pixels) and ability to scroll through pages. The keyboard itself is getting problematic. I've had to disable core isolation to get it to work, and now it needs to be plugged in and plugged out each time the PC starts. A new keyboard is likely needed! But I will likely loose my little screen with a new keyboard, so therefore starting the thread to ask what is the best small desktop monitor that works with AIDA64 for hardward monitoring. I have a HDMI (via MOBO) left and also USB ports left to use on this PC build. Cheers Quote
