timiman Posted September 29, 2023 Posted September 29, 2023 Just built a system based on cpu/mobo mentioned on title and I've found out that the temperature AIDA64 is reading for CPU Diode is the maximum of the n available thermal sensors on the CPU and not the average one. Is there a way to have two separate sensor readings for CPU Diode, one for Tjmax and one for Tavg -if it is available on ISA Dump ? Also, per core temperature will be a good feature to have. Usually the difference between them is a ~10oC on idle. (ex. Tjmax 69oC, Tavg 60oC) Both of features are available on other applications (ex. HWINFO, AMD Ryzen Master ) Thank you. PS. Latest AMD Chipset drivers set is installed 5.08.02.027, if it matters for reading the sensors. isasensordump.zip Quote
