I bought a 8.8" 1920x480 touch screen monitor from Temu to use as a sensor panel and ended up with two of them. I currently have them attached virtically to each side of my main monitor.  I was wanting to put GPU info on one side, CPU on the other, and then frame rate into on the LCD panel that I also have. Aidia64 does not allow me to have three sensor panels. (You can only get two if you have a USB LCD panel.)
My question is, what should I do with that 2nd Temu monitor? I am at a loss. It is secured to the side of the main monitor with some super magical doubled sided tape my Wife bought so it can be moved. Suggestions?
