Hi all,
my sensor panel has recently been preventing my monitors from going into standby mode.
I bought an OLED main screen about a month ago, which has to go into standby regularly to avoid burn in. AIDA64 sensor panel runs on a small internal IPS screen. So far, none of this has been a problem: after 5 minutes, all monitors went off.
Since a few days, the sensor panel prevents exactly this. To be precise, the monitors go off and then come back on again a second later. I found this out simply by trial and error. If I close the sensor panel display (AIDA64 continues to run in the background), everything is fine.
Does anyone know a solution?
