Data values shifting to the left - is there a way to reverse this
Newbie here. I did a search for this but didn't come up with anything.
I've built a sensor panel template and it includes some sensor items that display the written value. It looks like the results are justified to the right (so when the value increases, the length of the number moves to left). Is there a way to reverse this?
TIA
  • Sensor Moderators
Leave the 'Right-Align' box checked, so it will justify from right to left. Another way I use and works perfectly is to leave it centered. I create a document, in this case, in Photoshop, in the desired size, save it as a transparent PNG. Then, I create a new custom document and add the transparent file from 0 to 16. There you go, it will be centered. This way, it will always stay in the center.
