Sensor Panel Moves Monitors When Default Screen Is Changed
As title states, if you're changing primary monitor from the 'left' to the 'right' and the panel is on the left screen, it will move over to the right.
I have several screens and sometimes I'll change bottom center from primary to top center, and I normally have the panel on the top screen. So when this happens and I don't manually move the panel to the bottom screen first, it vanishes. The solution for this unless I revert changes is to hide and reshow the panel via right clicking the task manager icon. I would use the lock feature if this didn't happen.
