Tried with both NZXT CAM open and closed, but Aida64 sensors aren't picking up anything (liquid temp or radiator fan speed) from my NZXT Kraken Elite RGB 360. It is only picking up the pump speed since it's connected to my CPU_FAN header. My radiator fans are connected to my Kraken Elite, and my Kraken elite is connected to the motherboard via USB. I can see the info in HWinFO64 (again both with CAM open and closed) as shown below, so I don't think it's an issue with CAM blocking access to the device. I can also see the device in Aida64 > Devices > USB Devices.
Motherboard: Gigabyte x670e Aorus Pro X
Bios Version: F3 (Nov 8th, 2023)
CPU: Ryzen 7800x3d
AIO: NZXT Kraken Elite 360 RGB
RAM: TEAMGROUP T-Force Delta RGB DDR5 Ram 32GB (2x16GB) 6000MHz
GPU: Gigabyte GeForce RTX™ 4070 Ti AERO OC 12G
OS: Windows 11 Pro (22631.2861)
Version: Aida64 Extreme v7.00.6700
usbdump.txt
Exact same issue for me. I used to have the liquid temperature pull through from my Kraken Z63, but since upgrading to the Kraken Elite 360 i can't access the liquid temperature. Please could this be added in an update?
Haven’t tried with Aida64 since I posted this but I’ve been using InfoPanel (check their website for download/Discord, it’s on the MS Store but the website has the latest version), it’s a fantastic alternative and easy to use. Made this with it:
