mehim123 Posted May 13, 2013 Posted May 13, 2013 Im building my first rig here. I have the P8Z68-V MB I5 3570K Proc Corsair vengence 1600 Mhz 16Gb RAM H60 Corsair water cooler with push pull fan set up exhuasting to the rear NZXT Phanton case with a 200mm fan top 2 120's side my question is, all i can seem to get out of this chip is 4.5 Ghz and even at that i feel like im running a little on the hotter side. So i have stress tested it for a couple hours. and i seem to be seeing around 85 C for spike highs, 76 degrees or so at average. i believe im running about 1.33 volts let me know what you all think, i would really like to see some more overclock out of this but ive reseated my water block a few times and i just dont think i have the cooling power to get any more power out of it. Thanks yall
tw33k Posted June 22, 2013 Posted June 22, 2013 I'm not sure this is the best forum to be asking about overclocking. Maybe you should join overclock.net. Having said that, 1.3v is high for 4.5GHz. Does your chip really need that much voltage? What are you LLC settings?
Please sign in to comment
Sign In Now
