Due to an unplanned Win11 reinstall, I've just had to re-import my sensor panel, but I forgot to add the custom font first, it's the same font for every item.
Is there a way to change all the font universally?
I've tried it in 'Edit Defaults' & tried a replace all '<FNTNAM>font name</FNTNAM>' in Notepad++, but to no avail.
All you have to do is close Aida64, install the font, restart Aida64, load your panel, and it should be fine.
