rinaldop Posted January 17, 2024 Posted January 17, 2024 I am trying to make a custom graph with a gauge that gets longer to the left when FPS goes up and shrinks to the right as FPS goes down, like this <------ <--- <- I can do it if Aida64 can right justify custom gauges. Is there any way to do that? Thanks Quote
pro100tv Posted May 5, 2024 Posted May 5, 2024 You can just create a .png with transparency, and make the bar shorter on each frame. Quote
rinaldop Posted May 5, 2024 Author Posted May 5, 2024 4 hours ago, pro100tv said: You can just create a .png with transparency, and make the bar shorter on each frame. That is what I finally did! I will post the final panel tomorrow Quote
rinaldop Posted May 6, 2024 Author Posted May 6, 2024 On 5/5/2024 at 10:37 AM, pro100tv said: You can just create a .png with transparency, and make the bar shorter on each frame. Here it is! Quote
