SCUBA-FAN Posted February 15, 2024 Posted February 15, 2024 Odd behavior, but when I have Aida64 loading at startup, the NIC sensors do not appear on the sensor panel, but when I exit the app and restart it, they do appear. There are essentially five NICs in the PC, and the primary is the Realtek (NIC5 in Aida). All of them appear in Aida after restarting the app, but not when loading at windows boot. Weird. Any ideas for troublshooting this? Ethernet adapter Ethernet: Connection-specific DNS Suffix . : localdomain Description . . . . . . . . . . . : Realtek PCIe 5GbE Family Controller DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Lease Obtained. . . . . . . . . . : Wednesday, February 14, 2024 4:38:55 PM Wireless LAN adapter Wi-Fi: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : localdomain Description . . . . . . . . . . . : Intel(R) Wi-Fi 7 BE200 320MHz Wireless LAN adapter Wi-Fi 3: Media State . . . . . . . . . . . : Media disconnected Wireless LAN adapter Wi-Fi 5: Media State . . . . . . . . . . . : Media disconnected Ethernet adapter Bluetooth Network Connection: Media State . . . . . . . . . . . : Media disconnected 1 Quote
Serpster Posted March 21, 2024 Posted March 21, 2024 I have a similar issue, I'm not sure when it started, or on what version, but my sensor panel has only had this issue for 6 weeks or so. Essentially NIC5 does not show up, and the "Realtek PCIe 5GbE Family Controller" (under Network>Windows Network>Network Adapter Description) becomes assigned to NIC4. Switching to NIC4 displays the correct stats on the panel, until Aida64 is closed and launched again and it goes back to being assigned to NIC5. Restarting Windows starts all of this over again, requiring another close and relaunch to have NIC5 visible and assigned correctly. I am on v7.20.6802 and running on Win 11. Replying to hopefully get more visibility on the issue. 1 Quote
SCUBA-FAN Posted March 22, 2024 Author Posted March 22, 2024 4 hours ago, Serpster said: I have a similar issue, I'm not sure when it started, or on what version, but my sensor panel has only had this issue for 6 weeks or so. Essentially NIC5 does not show up, and the "Realtek PCIe 5GbE Family Controller" (under Network>Windows Network>Network Adapter Description) becomes assigned to NIC4. Switching to NIC4 displays the correct stats on the panel, until Aida64 is closed and launched again and it goes back to being assigned to NIC5. Restarting Windows starts all of this over again, requiring another close and relaunch to have NIC5 visible and assigned correctly. I am on v7.20.6802 and running on Win 11. Replying to hopefully get more visibility on the issue. This is exactly the same behavior I experience!!! 100%. bug for sure. 1 Quote
SCUBA-FAN Posted April 7, 2024 Author Posted April 7, 2024 April 7th and no response from anyone. Guess this is only happening to the two of us. 1 Quote
SCUBA-FAN Posted April 9, 2024 Author Posted April 9, 2024 On 3/21/2024 at 4:45 PM, Serpster said: I have a similar issue, I'm not sure when it started, or on what version, but my sensor panel has only had this issue for 6 weeks or so. Essentially NIC5 does not show up, and the "Realtek PCIe 5GbE Family Controller" (under Network>Windows Network>Network Adapter Description) becomes assigned to NIC4. Switching to NIC4 displays the correct stats on the panel, until Aida64 is closed and launched again and it goes back to being assigned to NIC5. Restarting Windows starts all of this over again, requiring another close and relaunch to have NIC5 visible and assigned correctly. I am on v7.20.6802 and running on Win 11. Replying to hopefully get more visibility on the issue. Curious if you have an Asus Motherboard? This issue is so repeatable and I can't beleive no one else is having this issue unless its very specific to us and our particular MB. 1 Quote
Maxiaid Posted October 24, 2024 Posted October 24, 2024 I'm having the exact same issue. Currently on v7.40. Quote Curious if you have an Asus Motherboard? Nope, MSI. 1 Quote
mhsmd Posted June 9, 2025 Posted June 9, 2025 Same thing here. I have NICs showing up on the OSD but not in the OSD config panel. Can't remove them. Quote
