I suppose that since I don't have an answer, it is not possible to use these templates in the OSD Panel.
I use a 7" monitor with a resolution of 1024X600 HDMI and the computer uses it as a second screen and it is the one I use as an aida64 sensor monitor but I can only use the OSD Panel.
I do not understand the question, why do you want to run an  OSD panel?
21 hours ago, Openmaximux said:
I don't know if of all the monitors that AIDA64 supports, any are compatible with mine.
In settings select sensor panel instead and you will see this windowScreenshot2024-02-23004501.png.8ca2e8ebddaaed909b264cd974f0882a.png.
Click 'show sensor panel' input your resolution and click apply.
You should see a sample template appear. Right click on it and select sensor panel manager and this window should appear
Click on import and load your template.
18 hours ago, Openmaximux said:
My monitoring screen is now working, thank you very much for your help.
I only have one thing left and that is that the Windows bar appears on the screen and I don't know how to remove it.
Go to taskbar properties in windows and UNCHECK show my taskbar on all displays
