  • NoCoO changed the title to HELP
1 hour ago, rinaldop said:
Try this, go to settings, general and select Load Aida64 at Windows startup.
I turned it on, and locked the sensor panel on the second screen, but when it started up, the sensorpanel appeared on the main screen.
Have you gone into Windows Display settings and made sure your multi monitor settings are correct? Post a screenshot of your Windows settings.
