Fl1nch Posted March 5, 2024 Posted March 5, 2024 Hello everyone, I edited a panel, saved and exported so I wouldn’t have to rework. Updated to the beta (extreme) and imported the panel, from my save location which had none of my changes. I’m looking to find out what I did wrong. Thank you Quote
rinaldop Posted March 6, 2024 Posted March 6, 2024 19 hours ago, Fl1nch said: Hello everyone, I edited a panel, saved and exported so I wouldn’t have to rework. Updated to the beta (extreme) and imported the panel, from my save location which had none of my changes. I’m looking to find out what I did wrong. Thank you I have no idea what could be the problem. Just as a test try it with the version of Aida64 that you created it with. Quote
Fl1nch Posted March 19, 2024 Author Posted March 19, 2024 On 3/17/2024 at 1:10 PM, Halfcutt said: If modifying a sensor panel, export the panel to a file frequently to save your changes. If you do not do this, and you load a new sensor panel, all changes you have made to previous panel will be lost. That is exactly what is happening, and it was driving me nuts. Essentially, exporting is the equivalent of saving? Quote
