AIDA64 Extreme won't show me CPU and MOB temps
Go to solution Solved by Rather Skinny,
Evening I've been trying all I can to add sensors or get my CPU and MOB temperatures inside AIDA64 without any luck. I've reinstalled the program and downloaded newest version. I'm using or trying to use a sensor panel template I bought from a guy out there and it's showing N/A on CPU and MOB and I seem not to be able to find any temps on that anywhere in the program. Out of curiosity I downloaded HWINFO and it displayed all the temperatures I wanted to see and was missing in AIDA64. However I've bought AIDA64 EXTREAME and would like to continue using the program.
So, my question is: Anyone else experiencing this problem with AIDA64, knows a solution on the matter or can point me into the right derection?
Currently running: AIDA64 Extreme v7.20.6802
PC SPECS:
CPU: i9-13900K | CPUC: Aorus Waterforce x 360 | GPU: Gigabyte RTX 4090 24GB | MOB: Gigabyte Z790 Aorus Master | PSU: Corsair RM1000i | RAM: Corsair Dominator DDR5 6400MHz (2x32GB) | SDD M.2: Samsung 990 + 980 PRO 2 TB(4Gen) & 970 PRO 500GB & 970 EVO 500GB | SDD: Samsung 840 EVO 120GB & 500GB | PCC: Lian Li O11 Dynamic XL |
12 hours ago, rinaldop said:
I gave this advice to another user with a similar problem.  Read this and see if it helps
Thanks, but thats not the issue. When right-clicking on on "cpu temperature" and clicking on "modify item" there is no CPU temp/ or MOB temp anywhere displayed on the Gauge list, only GPU related temperatures. I have looked everywhere in the program and cannot find it anywhere. It is clearly missing.
That is a serious issue, I hope a dev replies soon.
  • Solution
Found a solution, just wanted to share it.
I had the newest version of AIDA64 Extreme and uninstalling and reinstalling did nothing to fix the missing sensor temperatures. However after uninstalling the current version and going for the new "Beta version" it did display the sensor and it finally worked.
