can you help me
The problem I am having is my Fans for the CPU are not showing up in the Modify iterm list is not
mentioned or shown in the Cooling Fans and Fan Speeds section
my Version of AIDA64 Is v7.20.6802
so i send you my ISA Sensor Dump on the 20/4/2024 and you get back saying
Thank you!  Everything seems to be fine there.
I suppose your CPU fan was not shown in the list of the available sensor
items because the CPU fan wasn't spinning at that time.
so i send you this message saying
Even if the CPU fan wasn't spinning, it should be shown in the list as the same way
GPU Fans are shown even they remain at 0 RPM. I think, problem is somewhere else.
Please suggest!
but it has not Solve the issue
