CaptPola Posted June 29, 2024 Posted June 29, 2024 Hope everyone is well, I’m new to wigidash and AIDA64, I downloaded a really neat sensor panel but I noticed it doesn’t give me a read out of my AIO pump, it just at 0. For the FPS, there’s an active graph that’s live but the counter just remains 0. Any help would be appreciated!! Quote
rinaldop Posted June 29, 2024 Posted June 29, 2024 13 hours ago, CaptPola said: Hope everyone is well, I’m new to wigidash and AIDA64, I downloaded a really neat sensor panel but I noticed it doesn’t give me a read out of my AIO pump, it just at 0. For the FPS, there’s an active graph that’s live but the counter just remains 0. Any help would be appreciated!! Read all of this thread to solve the FPS issue https://forums.aida64.com/topic/12526-no-fps/ As for the pump, how is it connected to your computer? Try this first. Right click on the panel and select Sensorpanel Manager. Scroll down the list until you see the entry for AIO/PUMP Left click on it and select modify. You will now see a list of all the sensors on your computer that are being monitored. Scroll down to the fans section and see what is available for your AIO/PUMP Quote
wdnch Posted April 20, 2025 Posted April 20, 2025 Hello all, I also get no FPS on my sensor panel. I have RTSS up and running, an active game open but it's not working. I also tried the MSI afterburner method and even FRAPS where it displayed FPS for 1 second and then stopped. I just can't get it to work, everyone is saying install RTSS and that fixes it but it doesn't for me... I also have installed the normal Rivatuner, but that does nothing either. I have a 9800x3d and 7900xtx nitro. Help is very much appreciated, thank you. David Quote
wdnch Posted April 20, 2025 Posted April 20, 2025 Ok, I thankfully found a fix for my case already. I only tried it on CS2. When I started Borderlands 3 and RDR2 it worked suddenly. For CS2 you need to do this: Quote
