Problem with non-centered templates
David26
Ragazzi ho bisogno del vostro aiuto, ho un problema con i template aida64 in risoluzione 1920x480, il problema è che in qualsiasi template di questa risoluzione tutti i numeri, le lettere e gli sfondi si muovono e non sono centrati come quelli che vedo qui. Come posso fare? Grazie mille per il vostro aiuto
Ho pubblicato alcune foto di esempio, vengono tutte così quando imposto la risoluzione del pannello a 1920x480, il mio schermo è da 8,8 pollici . Grazie mille per il tuo aiuto.
Scaling issues?
Q: I import a sensorpanel and its changes the size and re-aranged objects
Q: How to avoid scaling problems with sensor panels?
A: Two things usually cause that
  • You do not have the proper font installed. (The default font is loaded instead)
  • You do not have Windows scaling set to 100%
A: When creating a sensor panel, make sure that you set the scaling in Windows to 100% and that the resolution in Aida64 is correct. The manually set sensor panel dimensions are saved directly in the sensor panel file and are automatically applied when loading for the first time.
Q: How to check the panel size?
  • Right click on "Aida64" Task bar Icon > Settings > SensorPanel > SensorPanel Size
Scaling issues? (Windows)
Fix: Try setting "DPI compatibility mode" for aida64.exe
It's a Windows compatibility setting that you apply on the EXE itself. Locate AIDA64.EXE (C:\Program Files (x86)\FinalWire\AIDA64 Extreme) aida64.exe > properties > compatibility > change high DPI settings > activate "Override high DPI Scaling behavior" to System. Scaling performed by: 'System' (from the drop down) > Ok/Apply > Restart Windows > Load/import panel and check if it works now.
Once you've done this, make sure that your SensorPanel properties are set to match the new panel before importing and you have a better chance of being successful.
Troubleshooting not working?
Users who have this scaling problem and cannot resolve the error with the known "fixes" unfortunately have to manually re-align each individual object.
3 hours ago, rinaldop said:
Problemi di scalabilità?
😧 Importo un pannello sensore e le sue dimensioni cambiano e gli oggetti vengono riorganizzati
😧 Come evitare problemi di ridimensionamento con i pannelli dei sensori?
A: Di solito due cose causano ciò
  • Non hai installato il font corretto. (Al suo posto viene caricato il font predefinito)
  • Il ridimensionamento di Windows non è impostato al 100%
R: Quando si crea un pannello sensore, assicurarsi di impostare la scala in Windows al 100% e che la risoluzione in Aida64 sia corretta. Le dimensioni del pannello sensore impostate manualmente vengono salvate direttamente nel file del pannello sensore e vengono applicate automaticamente quando si carica per la prima volta.
😧 Come posso controllare le dimensioni del pannello?
  • Fare clic con il tasto destro del mouse sull'icona della barra delle applicazioni "Aida64" > Impostazioni > SensorPanel > Dimensioni SensorPanel
Problemi di ridimensionamento? (Windows)
Correzione: provare a impostare la "Modalità di compatibilità DPI" per aida64.exe
È un'impostazione di compatibilità di Windows che applichi all'EXE stesso. Individua AIDA64.EXE (C:\Programmi (x86)\FinalWire\AIDA64 Extreme) aida64.exe > proprietà > compatibilità > modifica impostazioni DPI elevate > attiva "Ignora comportamento ridimensionamento DPI elevato" su Sistema. Ridimensionamento eseguito da: 'Sistema' (dal menu a discesa) > Ok/Applica > Riavvia Windows > Carica/importa pannello e verifica se ora funziona.
Una volta fatto questo, assicurati che le proprietà del SensorPanel siano impostate in modo da corrispondere al nuovo pannello prima dell'importazione: così facendo avrai maggiori probabilità di successo.
La risoluzione dei problemi non funziona?
Gli utenti che riscontrano questo problema di ridimensionamento e non riescono a risolvere l'errore con le "correzioni" note, purtroppo devono riallineare manualmente ogni singolo oggetto.
hello thanks a lot for the support. Finally with your guide I managed to get everything right, but now I have only one problem. In short when I go to insert the sensorpannel on the 8.8 inch monitor with the resolution 1920x480, the sensorpanel is longer than the monitor making it go on the main monitor, how can I make it fit from the small monitor?
