Scheffer Posted August 9, 2024 Posted August 9, 2024 Helo there. The CPU temperature is showing as N/A at the sensor panel. Can someone give me a hand on it? Tks. ida64 Sensor Panel.jfif Quote
rinaldop Posted August 12, 2024 Posted August 12, 2024 On 8/9/2024 at 11:26 AM, Scheffer said: Helo there. The CPU temperature is showing as N/A at the sensor panel. Can someone give me a hand on it? Tks. Try a different sensor. Right click the panel and open the sensorpanel manager. Go down the list until you find the entry for CPU temperature. Right click that and select modify. All the sensors that Aida64 can monitor will appear. Scroll down to the temperature section and see what is available for CPU. Quote
