GeForce RTX 3060 EAGLE 12G Sensor Item/Sensor Bar for GPU Cooling fans not working.
I have a Gigabyte RTX 3060 Eagle 12G and the sensor item/bar for the GPU cooling fan is not working.
I set my GPU max value as 3000 RPM and when the fan was rotating, the white bar remained at the starting point. As seen from my attached image, the GPU fan speed is at 830 RPM but the white bar did not change. I restarted my Windows and AIDA64 program but it remained the same. I have also attached the ISA sensor dump file for you to investigate.
The current AIDA64 version that I'm using is 7.35.7000.
Hope to hear from you soon.
isasensordump.txt
I just received an update notification and I have updated the AIDA64 version to 7.35.7008 and the GPU cooling fan sensor item/bar works perfectly.
