FatBoyNL Posted September 12, 2024 Posted September 12, 2024 This minor visual issue is a with an incorrect default icon used under Computer - Sensor: Cooling Fans. To be specific, it's about cooling fan CHA5 (= name in BIOS) aka Chassis #5 (= name in AIDA64) on my "ASUS ROG STRIX B650E-E Gaming WiFi" mobo. Two of my three chassis fans show the correct 'case' or 'chassis' icon, that is "Chassis #3" and "Chassis #4". The third case fan "Chassis #5" shows a blue 'AIO pump' icon I think, but it definitely is just another chassis fan (according to the BIOS Q-Fan settings & according to the ASUS mobo manual). I attached a picture of this below. EDIT: as you can see, I was able to change/update all names of all Cooling Fans. Just not the preferred icon(s).. 😞 Quote
FatBoyNL Posted September 26, 2024 Author Posted September 26, 2024 Issue persists in v7.35.7018 beta 😞 Should I post this again as a bug report? Quote
FatBoyNL Posted October 27, 2024 Author Posted October 27, 2024 HWinfo64 also shows this CHA_5 fan in BIOS as a Water Pump fan. Is this supposed to be fixed by ASUS? The ASUS Bios just shows CHA_5. Quote
FatBoyNL Posted October 27, 2024 Author Posted October 27, 2024 The BIOS name of the affected fan is "CHA_FAN5" btw - my bad 😉 Quote
FatBoyNL Posted March 13, 2025 Author Posted March 13, 2025 I'm happy to confirm that his specific fan icon issue finally has been fixed in v7.60.7311 Beta: Quote - .. - fixed: motherboard specific sensor info for Asus ROG Strix B650E-E Gaming WiFi - .. Great work, thanks! Quote
