I'm looking to add smart drive statuses for my hard drives to my sensor panel, currently the only option I can find is "Smart Status" which doesn't specify which drive it is referring to. IS this referring to all the drives? I.e. if any of the drives report SMART issues this will change to "not ok"?
I would like to break this down per drive if possible. Also I would like to understand at what point does the value change from "OK" to "Not-OK".
