Using iGPU for SensorPanel and AGPU for all else
I would like to use the integrated gpu of my Ryzen 7950X3D to display my SensorPanel on the 515X1920 Hyte Y60 screen.  While at the same time using my other dual monitors on my dedicated  RTX4090 GPU.  I'm using Win11.
Has anyone tried that?
Performance can vary based on what you’re running on each GPU, especially with high-demand applications on the RTX 4090. It's a good idea to monitor performance and adjust settings as needed. If you encounter any issues, double-check your BIOS settings and driver installations.
