cakeofruit Posted November 11, 2024 Posted November 11, 2024 hello could someone help me to achieve this as in the photo.I have tried everything for 4 days I can't get anything done, the images don't take up all the screen or this and written in very small Granzon GAMSC CPU Water Cooling Block w/ Temp Digital Display - Black 1440x1440 thank you for your help and sorry to disturb you in your activities Quote
cakeofruit Posted November 11, 2024 Author Posted November 11, 2024 I must have a problem with the size Quote
rinaldop Posted November 12, 2024 Posted November 12, 2024 Read this: Scaling issues? Q: I import a sensorpanel and its changes the size and re-aranged objects Q: How to avoid scaling problems with sensor panels? A: Two things usually cause that You do not have the proper font installed. (The default font is loaded instead) You do not have Windows scaling set to 100% A: When creating a sensor panel, make sure that you set the scaling in Windows to 100% and that the resolution in Aida64 is correct. The manually set sensor panel dimensions are saved directly in the sensor panel file and are automatically applied when loading for the first time. Q: How to check the panel size? Right click on "Aida64" Task bar Icon > Settings > SensorPanel > SensorPanel Size Scaling issues? (Windows) Fix: Try setting "DPI compatibility mode" for aida64.exe It's a Windows compatibility setting that you apply on the EXE itself. Locate AIDA64.EXE (C:\Program Files (x86)\FinalWire\AIDA64 Extreme) aida64.exe > properties > compatibility > change high DPI settings > activate "Override high DPI Scaling behavior" to System. Scaling performed by: 'System' (from the drop down) > Ok/Apply > Restart Windows > Load/import panel and check if it works now. Once you've done this, make sure that your SensorPanel properties are set to match the new panel before importing and you have a better chance of being successful. Troubleshooting not working? Users who have this scaling problem and cannot resolve the error with the known "fixes" unfortunately have to manually re-align each individual object. Quote
