Posted (edited)
Hey guys, I'm after a sensor panel in above resolution.  Looking for something simple.  Will be happy to donate to some one who helps me along the way.  Im running Alienware monitors and it will sit underneath that for a rough colour scheme.
Thanks !
Edited by Jimmeh081
spelling mistakes
  • Sensor Moderators
Thanks !
Use the custom search in the top right corner to check for available models. However, there are no options for the 140x320 resolution.
  • COSTAJUNIOR changed the title to painel sensor 140x320
  • Jimmeh081 changed the title to panel sensor 1480x320
  • 3 weeks later...
