Hi all,
I am a complete newbie to Aida64 and sensor pannels.
I recently purchased this 12.3in (1920x720) panel and got it up and running.
Problem is I cannot seem to find any template for this size and resolution. I know I should have done my research first and gotten a different size panel. I have been playing around with some template I have downloaded here (thanks everyone) but cannot get any to fit.
I was wondering if anyone wouldnt mind sharing a template, even a basic one so that I can see what it should look like and begin playing around more.
Thanks
Ryan
  • Sensor Moderators
Friend, in the top-right corner, there's a magnifying glass that allows you to search for the resolution you mentioned. I conducted a search but didn't find any skin with that resolution.
  • Thanks 1
8 hours ago, TheFreak666 said:
Thank you CostaJunior,
I did have a look via that method and had the same outcome as you. I appreciate you trying and looking for me
The resolution that you have mentioned 1920x780 is not that common. Please check the resolution again as commented by JariKoi as it seems to be 1920x720
If the resolution is 1920x780 then please read below else ignore:
You have two solutions:
THE BEST METHOD:
1. Download any panel from the thread, which is near your resolution specs (as mentioned by JariKoi above) and play around with it to convert it to resolution required:
https://forums.aida64.com/topic/13296-share-your-sensorpanels/?_fromLogin=1
While converting, if you face any issues or have any questions/concerns, you can always post them in the above thread as everyone there is very supportive and happy to help!
THE METHOD WHICH IS THE LAST RESORT:
2.A few people are interested in making the panels for you with a nominal fees.
If you need any help or information around anything, please dont hesitate to reach out!
  • Thanks 1
Apologies for the typo in my written section; I meant to write 1920x720.  Thank you for picking this up.
Ill start to have a play around with the advice you just gave and try converting some.
Much appreciated :)
  • Like 2
