Chooch8185 Posted January 28, 2025 Posted January 28, 2025 i have a 480x800 sensor panel. everything is working except my FPS counter. How do i make it work? Quote
BrYuan Posted January 28, 2025 Posted January 28, 2025 You need to install RSS (Rivatuner Statistics Server). Use Google search to search for 'Rivatuner' After finished installing it, open the RSS. At the top left corner, under 'Start with Windows', switch it to 'ON'. Next, go to 'setup' (bottom blue button), click the 'Start minimized'checkbox. The FPS counter will appear on you sensor panel automatically while gaming. Quote
