Eve182 Posted April 18, 2025 Posted April 18, 2025 Hi all, cannot find this issue on the internet. I experienced it twice. My sensor panel that I designed, with hours of work, is gone and back to the basic blue screen that you start with after first installing AIDA. I've had this 2 years ago, I think after/because I updated AIDA. Since then, I never updated AIDA, but I think I (or the misses) by accident clicked yes on the popup message saying there was an update available, and now again I am back to the default blue sensor panel. Very very annoying. Anyone recognises this issue? Is there a way I can recover my design? What can I do to prevent this in the future? Thx for any tips. Kind regards, Yves Sannen Quote
Loyd Posted May 10, 2025 Posted May 10, 2025 save your work by exporting it then import back. this cleans up all the pointers and stuff in the background and gives you a backup copy of you skin. Quote
