KomSoMol Posted August 27, 2025 Posted August 27, 2025 Hello Forum! I do not know if such a topic is in place here, but I desperately need help. About a month ago I assembled a new PC with the following config: Motherboard - MSI Pro B650M-B (MS-7E28) CPU - HexaCore AMD Ryzen 5 7500F, 4044 MHz RAM - G Skill F5-5600J3036D16G 16 GB DDR5-5600 DDR5 SDRAM Video Adapter - NVIDIA GeForce RTX 5060 (8 GB) Disk Drive - STM3500418AS (500 GB, 7200 RPM, SATA-II) Disk Drive - KINGSTON SKC600512G (512 GB, SATA-III) Disk Drive - KINGSTON SV300S37A60G (60 GB, SATA-III) Disk Drive - MSI M371 1TB (1024 GB, PCI-E 3.0 x4) BIOS Type AMI (12/11/2024) A fresh Windows 10 installed, with latest updates. But just a week after that I've started getting my PC occasionally reboot. This may happen randomly. Sometimes 4-6 times in a row with intervals of 2-10 minutes between reboots. And sometimes the PC may work fine in hours, without such occasions. Every time the scenario is the same: - the sound disappears - at the same time, the picture on the screen freezes, with no signs of activity. PC stops resonding to any commands - in 4-7 seconds after that, a reboot happens All the ways to solve this issue, that are known to me, are in vain - reboots continue to appear. AIDA64 40-minutes-long stress test discovers no instability or issues with either voltage, temperatures, powers, or clocks. Every time Windows logs show pretty identical sequence of events leading to the reboot: Could anyone help me to fix this issue once and for all? I can provide you with any kind of information about my PC, and endless gratitude. Quote
KomSoMol Posted August 29, 2025 Author Posted August 29, 2025 solved by BIOS updating to 7E28vAF AMI (06/19/2025) Quote
