Hi. Your program says that it not supports the 5 GHz band for the h96 pro plus tv box but all the stores that sell this product are supporting the 2.4 GHz / 5.8 GHz WiFi band. How that happens?
Such issues could happen when the platform designer (in your case Alfawise) fails to encode the proper information in the Android WiFi profile to indicate the true capabilities of the WiFi controller.  We'll implement a workaround in the next AIDA64 for Android app update.
On ‎2018‎. ‎02‎. ‎26‎. at 2:29 PM, Mirfail said:
So this does not mean that the TV box is not supporting the 5 GHz band. It can be a mistake in encoding if supported.Is that so?
Yes, it's only a cosmetic issue that doesn't actually effect the capabilities of the WiFi controller.
  • 3 years later...
