mito Posted September 22, 2018 Posted September 22, 2018 Basic Properties Device iPad Pro 2 Dock Connector Lightning SIM Card Type Not Available Device String iPad7,1 Device Id J120AP Released Jun 12, 2017 Capabilities Cellular No GPS No NFC No Force Touch No Bluetooth Version 4.2 Controller Murata/Apple 339S00249 Bluetooth Smart (LE) Yes Physical Properties Width 220.6 mm Height 305.7 mm Depth 6.9 mm Weight 713 g CPU Properties CPU Apple A10X Speed 2380 MHz Manufacturer TSMC Instruction Set 64-bit ARMv8-A Microarchitecture Fusion Technology 16 nm Core Count 3 Active Core Count 3 GPU Properties GPU Type PowerVR Series7 GPU Cores 12 Co-processor Properties Co-processor Apple M10 Storage Information Device Model 64 GB Total Storage 59.60 GB Available Storage 4.41 GB RAM Information Total RAM 3974 MB Available RAM 180 MB Screen Size Screen Size 12.9" Aspect Ratio 4:3 Pixel Density 264 PPI Screen Parameters Vertical Resolution 2732 Pixels Horizontal Resolution 2048 Pixels Contrast 800:1 Brightness 500 cd/m² Technology IPS Refresh Rate 120Hz Color Gamut DCI-P3, True Tone Back Camera Resolution 12 MegaPixels Aperture 1.8 Max Video Resolution 4k @ 30fps Max Video Speed 240fps @ 720p Optical Stabilization Yes Max Photo Resolution 4032 x 3024 Shortest Exposure Value 1/500000 sec Longest Exposure Value 1/3 sec Front Camera Resolution 7 MegaPixels Aperture 2.2 Max Video Resolution 1080p @ 30fps Max Video Speed 30fps @ 1080p Optical Stabilization No Max Photo Resolution 3840 x 2160 Shortest Exposure Value 1/76923 sec Longest Exposure Value 1/2 sec Assigned IP Addresses Wi-Fi (IPv4) 192.168.xxxx Wi-Fi (IPv6) .... Cellular (IPv4) Not Available Cellular (IPv6) Not Available Wi-Fi Details SSID maria BSSID c4:12:f5:67:19:c0 Capabilities 802.11 a/b/g/n/ac Controller Murata/Apple 339S00249 Battery Status Charging Level 83 % Voltage 3.8 V Capacity 10875 mAh Type Li-Ion Polymer Battery Details Charge 0 / 0 mAh (nan %) Wear Level 100.00 % Voltage 0.000 V Adapter Details Installed OS Operating System iOS Version 12.0 Build Number 16A366 OS State Stable Multitasking Yes Current Session Active Time 0d 5h 35m Uptime 0d 5h 33m OS Compatibility Initial OS Version iOS 10.3.2 Max Supported OS Version iOS 11+ AIDA64 for iOS Version 1.17 (357) Quote
Mice007 Posted September 22, 2018 Posted September 22, 2018 Unfortunately it is not possible to obtain any battery info under iOS 12. We'll soon publish an update to AIDA64 App to not display the false values. You can check battery health in iOS Settings / Battery page. Quote
mito Posted September 24, 2018 Author Posted September 24, 2018 On 9/22/2018 at 4:35 AM, Mice007 said: Unfortunately it is not possible to obtain any battery info under iOS 12. We'll soon publish an update to AIDA64 App to not display the false values. You can check battery health in iOS Settings / Battery page. thanks! Quote
