First problem: I have problem with my OSDpanel, while playing for example Pubg I have "Cpu" and "Gpu" temps and they wont stay as top most window.
Second problem: My sensorpanel every time i click (left and right) on my desktop the sensorpanel closes and opens it takes between 0,5 and 1 seconds. If I right click on my desktop the sensorpanel disappears and the normal windows drop-down menu comes up for a good 0,5 to 1 seconds and then closes and the sensorpanel pops back where it should be. It is just a little annoying because i can not while the sensorpanel is showing change any thing in the drop-down menu. My friend does not have the problem and I can not find the issue... (My spelling isnt perfect but hey its not that important)
