The sensor panel will drop out from time to time. Maybe in as little as two hours or as far apart as several days. Closing the program and restarting does not solve the problem. The system is a gigabyte x570 master - 3900x and Asus 5700XT.  Below are two captures of the sensor readings.   The only way I have been able to resolve this is to restart the computer. I do not have any other monitoring programs running.  Any ideas as to the cause of this? As far as i can tell the fans and pump continue to operate as normal during this time.
Thank You
