AMD Chipset Identification Problems inside Physical Devices and PCI Devices Pages
AIDA should identify the PCI-Devices of the current AMD Chipsets (3xx/4xx/5xx for Zen/Zen2/Zen3) inside the PCI-Device-Page but it doesnt!
Problem:
On a system with AMD B450 or X470 Chipset, AIDA shows the parts of the Chipset as "AMD Low-Power Promontory Chipset" instead of B450.... or X470
On a system with AMD A520 or B550 as "AMD 500-Series Chipset".
Its "very" easy to display the right things - the first device of the chipset (USB XHCI) helps to identify the chipset:
A320/B350/X370/X399:
43B9 - X370 USB XHCI
43BA - X399 USB XHCI
43BB - B350 USB XHCI
43BC - A320 USB XHCI
This could/should be used for the other parts of the chipset
43B5/43B5/43B7/43B8 - SATA
43BD - SATA RAID
43B0/43B1/43B2/43B3 - SUP
43B4 - SDP
B450/X470:
43D0 - X470 USB XHCI
43D5 - B450 USB XHCI
43C8 - SATA
43C6 - SUP
43C7 - SDP
A520/B550:
43EC - A520 USB XHCI
43EE - B550 USB XHCI
43EB - SATA
43E9 - SUP
43EA - SDP
SUP = Switch Upstream Port
SDP = Switch Downstream Port
So instead of
Bus 2, Device 8, Function 0    AMD 500-Series Chipset - GPP-Switch Downstream Port
Bus 1, Device 0, Function 1    AMD 500-Series Chipset - SATA AHCI Controller
Bus 1, Device 0, Function 2    AMD 500-Series Chipset - Switch Upstream Port
Bus 1, Device 0, Function 0    AMD 500-Series Chipset - USB 3.1 xHCI Controller
AIDA should show:
Bus 2, Device 8, Function 0    AMD B550 - GPP-Switch Downstream Port
Bus 1, Device 0, Function 1    AMD B550 - SATA AHCI Controller
Bus 1, Device 0, Function 2    AMD B550 - Switch Upstream Port
Bus 1, Device 0, Function 0    AMD B550 - USB 3.1 xHCI Controller
For the "missing" chipset 43ED AIDA should continue to use "AMD 500-Series Chipset"
In Delphi this could look like:
// AMD Promontory 3xx Chipsatz
        $43B0 : begin
                Result:=SubPCIName2('SB PCIe Port (Switch USP)','AMD PCIe USP', iH_BUS_PCIE);
                if _SBAMD<>'' then Result:=SubPCIName2(_SBAMD + PCICL_BUS_PCISWU, _SBAMD + 'USP', iH_BUS_PCIE);
                end;
        $43B1 : begin
                end;
        $43B2 : begin
                end;
        $43B3 : begin
                end;
        $43B4 : begin
                Result:=SubPCIName2('SB PCIe Port (Switch DSP)','AMD PCIe DSP', iH_BUS_PCIE);
                if _SBAMD<>'' then Result:=SubPCIName2(_SBAMD + PCICL_BUS_PCISWD, _SBAMD + 'DSP', iH_BUS_PCIE);
                end;
        $43B5 : begin
                Result:=SubPCIName1('SB SATA Controller','SATA');
                if _SBAMD<>'' then Result:=SubPCIName1(_SBAMD + PCICL_STOR_SATA, _SBAMD + 'SATA');
                end;
        $43B6 : begin
                end;
        $43B7 : begin
                end;
        $43B8 : begin
                end;
        $43B9 : begin _SBAMD:='X370 '; Result:=SubPCIName1(_SBAMD + PCICL_USB_XHCI31, _SBAMD + 'XHCI'); end; //ASM2016A
        $43BA : begin _SBAMD:='X399 '; Result:=SubPCIName1(_SBAMD + PCICL_USB_XHCI31, _SBAMD + 'XHCI'); end; //ASM2016B
        $43BB : begin _SBAMD:='B350 '; Result:=SubPCIName1(_SBAMD + PCICL_USB_XHCI31, _SBAMD + 'XHCI'); end; //ASM2016C
        $43BC : begin _SBAMD:='A320 '; Result:=SubPCIName1(_SBAMD + PCICL_USB_XHCI31, _SBAMD + 'XHCI'); end; //ASM2016D
        $43BD : begin
                Result:=SubPCIName2('Promontory SATA RAID Controller','Promontory', iH_DISK_RAID);
                if _SBAMD<>'' then SubPCIName2(_SBAMD + PCICL_STOR_SATA_R,'Promontory', iH_DISK_RAID);
                end;
// Low Power Promontory 4xx Chipsatz
        $43C6 : begin
                end;
        $43C7 : begin
                end;
        $43C8 : begin
                Result:=SubPCIName1('Promontory SATA Controller','Promontory');
                if _SBAMD<>'' then Result:=SubPCIName1(_SBAMD + 'SATA Controller','Promontory');
                end;
        $43D0 : begin _SBAMD:='X470 ';   Result:=SubPCIName1(_SBAMD + PCICL_USB_XHCI31, _SBAMD + 'XHCI'); end;
        $43D1 : begin _SBAMD:='B550A ';  Result:=SubPCIName1(_SBAMD + PCICL_USB_XHCI31, _SBAMD + 'XHCI'); end;
        $43D2 : begin _SBAMD:='Pro560 '; Result:=SubPCIName1(_SBAMD + PCICL_USB_XHCI31, _SBAMD + 'XHCI'); end;
        $43D5 : begin _SBAMD:='B450 ';   Result:=SubPCIName1(_SBAMD + PCICL_USB_XHCI31, _SBAMD + 'XHCI'); end;
        $43D3 : begin _SBAMD:='?43D3 ';  Result:=SubPCIName1(_SBAMD + PCICL_USB_XHCI31, _SBAMD + 'XHCI'); end;
        $43D4 : begin _SBAMD:='?43D4 ';  Result:=SubPCIName1(_SBAMD + PCICL_USB_XHCI31, _SBAMD + 'XHCI'); end;
        $43D6 : begin _SBAMD:='?43D6 ';  Result:=SubPCIName1(_SBAMD + PCICL_USB_XHCI31, _SBAMD + 'XHCI'); end;
        $43D7 : begin _SBAMD:='?43D7 ';  Result:=SubPCIName1(_SBAMD + PCICL_USB_XHCI31, _SBAMD + 'XHCI'); end;
        $43D8 : begin _SBAMD:='?43D8 ';  Result:=SubPCIName1(_SBAMD + PCICL_USB_XHCI31, _SBAMD + 'XHCI'); end;
        $43D9 : begin _SBAMD:='?43D9 ';  Result:=SubPCIName1(_SBAMD + PCICL_USB_XHCI31, _SBAMD + 'XHCI'); end;
        $43DA : begin _SBAMD:='?43DA ';  Result:=SubPCIName1(_SBAMD + PCICL_USB_XHCI31, _SBAMD + 'XHCI'); end;
        $43DB : begin _SBAMD:='?43DB ';  Result:=SubPCIName1(_SBAMD + PCICL_USB_XHCI31, _SBAMD + 'XHCI'); end;
        $43DC : begin _SBAMD:='?43DC ';  Result:=SubPCIName1(_SBAMD + PCICL_USB_XHCI31, _SBAMD + 'XHCI'); end;
        $43DD : begin _SBAMD:='?43DD ';  Result:=SubPCIName1(_SBAMD + PCICL_USB_XHCI31, _SBAMD + 'XHCI'); end;
        $43DE : begin _SBAMD:='?43DE ';  Result:=SubPCIName1(_SBAMD + PCICL_USB_XHCI31, _SBAMD + 'XHCI'); end;
        $43DF : begin _SBAMD:='?43DF ';  Result:=SubPCIName1(_SBAMD + PCICL_USB_XHCI31, _SBAMD + 'XHCI'); end;
// AMD 5xx Chipsatz
        $43E9 : begin
                Result:=SubPCIName2('SB ' + PCICL_BUS_PCISWU,'AMD PCIe USP', iH_BUS_PCIE);
                end;
        $43EA : begin
                Result:=SubPCIName2('SB ' + PCICL_BUS_PCISWD,'AMD PCIe DSP', iH_BUS_PCIE);
                end;
        $43EB : begin
                end;
        $43EC : begin _SBAMD:='A520 ';   Result:=SubPCIName1(_SBAMD + PCICL_USB_XHCI31, _SBAMD + 'XHCI'); end;
        $43ED : begin _SBAMD:='???? ';   Result:=SubPCIName1(_SBAMD + PCICL_USB_XHCI31, _SBAMD + 'XHCI'); end;
        $43EE : begin _SBAMD:='B550 ';   Result:=SubPCIName1(_SBAMD + PCICL_USB_XHCI31, _SBAMD + 'XHCI'); end;
Report_B550.txt Report_A520.txt Report_B450.txt Report_X470.txt
