BigLou Posted August 29, 2021 Posted August 29, 2021 I would like to be able to use the mouse or a touch screen to drill-down to other statistics. As an example, let's say that my main sensor panel has a gauge that displays CPU utilization. Clicking on the CPU gauge causes AIDA64 to import a sub-panel that contains utilization graphs for each thread. Then to exit the drill-down, use something like an "Exit" button on the sub-panel that re-imports the main panel. It doesn't seem like this would be difficult to implement, but I have no idea of the code complexity behind ADIA64 sensor panel implementation. Thanks Quote
Hi Whee Posted September 1, 2021 Posted September 1, 2021 On 8/29/2021 at 12:24 PM, BigLou said: I would like to be able to use the mouse or a touch screen to drill-down to other statistics. As an example, let's say that my main sensor panel has a gauge that displays CPU utilization. Clicking on the CPU gauge causes AIDA64 to import a sub-panel that contains utilization graphs for each thread. Then to exit the drill-down, use something like an "Exit" button on the sub-panel that re-imports the main panel. It doesn't seem like this would be difficult to implement, but I have no idea of the code complexity behind ADIA64 sensor panel implementation. Thanks Quote
