Zachary Gurley Posted September 11, 2021 Posted September 11, 2021 Im running an asus ROG Strix x570-e Gaming motherboard with a custom water loop. The T_Sensor always shows up in bios, and doesnt want to show up in Aida 64 on boot. What ive found through tinkering is that it will work only if i open HWID Info and run sensors. After HWID info shows the sensor it will work with my Aida 64 until i reboot Quote
Elderdeekey Posted September 23, 2021 Posted September 23, 2021 Same here with STRIX Z390-E_Gaming with the latest stable AND beta versions. HWMonitor started once with sensor enabled fix the problem... Dear Fiery, could you please look into this, thank you! Quote
Znaint Posted September 29, 2021 Posted September 29, 2021 Same issue here Gigabyte Aero G. Have to set it up every time I log in. Please address. I like seeing my coolant temp Quote
