criskoe Posted October 21, 2021 Posted October 21, 2021 I have a Maximus XII Extreme and Im missing both the DRAM and Drive temperature values on the sensor page and my LCD items.. I do have DIMM thermal sensor support enabled under preferences and Im running Aida64 version 6.33.5766 Beta. Also my voltage value for DIMM (Memory DRAM) is incorrect. It look's like its showing half the normal value??? All the values show up and are correct in HWiNFO64. Any Help? Quote
criskoe Posted November 1, 2021 Author Posted November 1, 2021 Update. So I uninstalled Aida 64 and then manually deleted the remaining files that didnt get removed in the uninstall. Restarted and then Re installed Aida. My drives and dram temps now show up! YEAH! But my Memory DRAM DIMM Voltage is still wrong. Still shows half the correct value. Quote
