krepslein Posted December 1, 2021 Posted December 1, 2021 I just bought a LCD screen with a resolution of 1280x800 but I mounted it in place of my rear exhaust fan so I had to mount it vertically. So the resolution is really 800x1280 and I can't seem to find any sensor panel downloads with that resolution. I've found 3 so far but the gauges are too small and I can't really read that text on the panel. I've tried searching through a bunch of pages on the "Aida64 Share Your Sensor Panel" page but I'm not having any luck. Their "search" feature brings up 5 results but only 3 of them are actually sensor panel downloads and those 3 are hard to read given the location of my sensor panel. Figured I would ask around and see if I can get any help cinema hd. Quote
Alpharius68 Posted December 1, 2021 Posted December 1, 2021 Hi @krepslein there are actually quite a few 800x1280 panels available, but it seems that the upload files have had their names modified. Sensor panels should have the file extension .sensorpanel at the end, but some have a lot of other charectors added... just rename the file to .sensorpanel and you are good. Here are a couple you can use to get you going, if you like them just find who made them and like their entry These for example were created by Racqn, but there are plenty more in the pages. Racqn_rainbow_800_1280.sensorpanel racQn_vertical_800_1280_sensorpanel.9ece2979e1450998d21cb56e8ba41feb 1 Quote
