3 hours ago, CoCo4eK said:
Can you help me i have 64 bit version but it says it uses 32 bit there is screenshot please check it
Please note that AIDA64 shows the current CPU instruction set, as it is utilized by the Android platform.  So when your Android platform is 32-bit, AIDA64 will show 32-bit CPU instruction set.  It's normal that many 64-bit capable Android devices have a 32-bit Android platform installed.  You can only convert an Android platform to 64-bit by installing a new Android firmware update that is 64-bit.  You need to consult with the manufacturer of your device and inquire them whether they have such an update for your device.
