BigWapo Posted March 8, 2022 Posted March 8, 2022 I have a Phantek p600 an was wondering where I should mount it. I have an exhaust fan where I can’t mount it in the back. And have really no room anywhere else. Was wondering if anyone had any ideas. Quote
Awol Posted March 10, 2022 Posted March 10, 2022 I have a Lian Li Lancool 1 i attached my panel to the top exhaust fans. Quote
BigWapo Posted March 15, 2022 Author Posted March 15, 2022 On 3/10/2022 at 11:19 AM, Awol said: I have a Lian Li Lancool 1 i attached my panel to the top exhaust fans. How did you attach them to the fans like that? Quote
Awol Posted March 15, 2022 Posted March 15, 2022 2 hours ago, BigWapo said: How did you attach them to the fans like that? I attached 2 of the posts to the screen, i used this as an anchor point. I then removed a screw from a corner of 2 of the fans. This i where it got tricky, get someone to hold the screen in place, use a long cable to tie and run it around the post up through the hole of the fan, attach to the other end and tighten. Do this for the other side also, this is just a temporary measure, im trying to work out how to make a bracker for a permanent mount. Quote
BigWapo Posted March 19, 2022 Author Posted March 19, 2022 On 3/15/2022 at 7:40 AM, Awol said: I attached 2 of the posts to the screen, i used this as an anchor point. I then removed a screw from a corner of 2 of the fans. This i where it got tricky, get someone to hold the screen in place, use a long cable to tie and run it around the post up through the hole of the fan, attach to the other end and tighten. Do this for the other side also, this is just a temporary measure, im trying to work out how to make a bracker for a permanent mount. so run like a post to the fan than use like a zip tie to that an have it go thru the corner. Quote
