tw33k Posted March 29, 2022 Posted March 29, 2022 I had Aida64 running at startup and as soon as it loads my monitors go dark and Windows is not responsive. I managed to get into Windows and disable Aida64 from running at startup, everything is working. If I run Aida64, the problem is back. Windows 11 22581.100.0 Radeon 5500XT 30.0.15019.1005 Quote
tw33k Posted March 29, 2022 Author Posted March 29, 2022 I read a couple posts here about problems with AMD cards and the Sensor Panel. I uninstalled Aida64 and ran the latest Beta. I was scrolling through the Preferences when the computer locked up and eventually rebooted Quote
Awol Posted March 29, 2022 Posted March 29, 2022 My build is AMD and i have no issues Ryzen 5 5600 X Radeon RX 6700 XT Gaming X. Maybe its Win11 that's the issue, i run Win 10 Quote
tw33k Posted March 30, 2022 Author Posted March 30, 2022 I reset the PC and this time did not install the Win 11 preview. It's now running 22000.593. I installed Aida64 set the Sensor Panel display size and selected Show Sensor Panel. As soon as I hit Apply, both monitors went black and I had to hard reset the PC Quote
tw33k Posted March 30, 2022 Author Posted March 30, 2022 20 hours ago, Awol said: My build is AMD and i have no issues Ryzen 5 5600 X Radeon RX 6700 XT Gaming X. Maybe its Win11 that's the issue, i run Win 10 Hey man...can you tell me what Radeon driver version you're running and do use the Adrenalin software? Quote
tw33k Posted March 30, 2022 Author Posted March 30, 2022 I tried the latest Aida64 beta on and exactly the same thing happened. Everything is fine but as soon as I choose Show Sensor Panel and hit apply...bad things happen. I don't know if it's helpful but attached is the error from Event Viewer. Both times it happened today, the error is the same Aida64_error.txt Quote
Awol Posted March 30, 2022 Posted March 30, 2022 Using driver version 22.3.1 and yes im using the latest adrenalin software. Win10 OS build 19044.1620 Quote
tw33k Posted March 30, 2022 Author Posted March 30, 2022 2 hours ago, Awol said: Using driver version 22.3.1 and yes im using the latest adrenalin software. Win10 OS build 19044.1620 Thanks. What about when you right-click your graphics card in device manager, what driver version? Quote
tw33k Posted March 31, 2022 Author Posted March 31, 2022 I've uninstalled the current version of AMD Adrenalin and the Radeon driver and gone back to the previous versions and everything seems to be working again. Quote
tw33k Posted April 9, 2022 Author Posted April 9, 2022 I installed a fresh copy of Windows 11 (22581.100.0) and updated the graphics driver to 30.0.15019.1005. Aida64 's sensor panel causes this problem. The system only had Windows installed, up to date drivers and Aida64. It appears that there's a conflict between Aida64 and the latest Radeon driver. Rolling back the driver fixes the problem. Quote
tw33k Posted April 12, 2022 Author Posted April 12, 2022 Juist updated Aida64 to 6.70 and now there is no problem with the latest Radeon driver and software. Quote
