Solution PapaKev Posted April 3, 2022 Solution Posted April 3, 2022 Reading through the forums I saw that it was suggested to update to the Beta version, which I did. However that did not fix the issue. AIDA64 reports 1/4 of the actual Mem Clock MHz. The GPU clock is reported correctly. Running Windows 10. Thanks Quote
PapaKev Posted April 10, 2022 Author Posted April 10, 2022 I just found the correction section under hardware monitoring. Changed the ratio from 1 to 4 for the GPU Memory clock. Feel like a derp. Quote
