I have an android box mecool km2. I want to install the citra and athersx2 but it requiring a 64 bit OS, although the mecool km2 has a CPU capable of handling a 64 bit OS it run a 32 bit OS. Can i install an 64 bit OS? And if i can how i can do it?
You can only convert an Android platform to 64-bit by installing a new Android firmware update that is 64-bit.  You need to consult with the manufacturer of your device and inquire them whether they have such an update for your device.
