fixed: A problem with AIDA64 sensors causing the system to freeze (Jginyue X99M-Plus V2)
Gar_Pheld
6 hours ago, Gar_Pheld said:
Hello. Faced on the motherboard x99M PLUS V2 with such a problem as the system freezing when the sensor PCH was sent. You can make this sensor disabled by default at startup Aida64? Thank you in advance
  • Fiery changed the title to A problem with AIDA64 sensors causing the system to freeze (x99M PLUS V2)
------[ Versions ]------
Program Version : AIDA64 Extreme v6.70.6028 Beta
BenchDLL Version: 4.5.868.8-x64
Windows Version : Microsoft Windows 10 Pro 10.0.19044.1766 (64-bit)
GetProductInfo  : 0x00000030
Motherboard ID      : 63-0100-000001-00101111-091015-Chipset$0AAAA000_BIOS DATE: 10/15/20 17:27:36 VER: 05.0000B
Motherboard Model   : Unknown Motherboard
Motherboard Chipset : Intel Lynx Point H81, Intel Haswell-EP
DMI MB Manufacturer : JGINYUE
DMI MB Product      : X99M-PLUS V2
DMI MB Version      : V2.0
DMI MB Serial       : MB-202101262021
DMI SYS Manufacturer: Default string
DMI SYS Product     : Default string
DMI SYS Version     : Default string
DMI SYS Serial      : Default string
DMI BIOS Version    : 5.11
ITE SuperIO Port           = 00h
ITE SuperIO HWMonitor Port = 0000h     (    0000h /     0000h)
ITE SuperIO HWMonitor MMIO = 00000000h (00000000h / 00000000h)
ITE SuperIO Device ID      = 0000h     (    0000h /     0000h)
ITE SuperIO Version        = 00h       (      00h /       00h)
Winbond SuperIO Port              = 2Eh
Winbond SuperIO HWMonitor Port/60 = 0A20h (0A20h / 0000h)
Winbond SuperIO Device ID         = C562h (C562h / 0000h)
Winbond Sensor ID A3/5C/reg$58    = A3 / 5C / C1
ASpeed SuperIO Port = 00h
------[ Nuvoton ISA Sensor Device at 0A20 / Bank #0 ]------
0000  03 64 03 82  00 FF FF FF  FF FF FF FF  FF FF FF FF
0010  03 7F 03 FF  03 FF FF FF  40 84 12 0F  FF 9A 13 00
0020  23 00 D3 D2  00 00 FF 31  FF FF FF DA  00 00 00 00
0030  00 00 00 00  00 00 00 00  00 00 00 FF  FF FF FF FF
0040  03 00 50 FF  DF 00 1F FF  2D FF FF 10  08 55 01 A3
0050  01 FF FF FF  FF FF FF FF  C1 FF FF FF  FF 47 04 FF
0060  AA FF FF FF  FF 01 00 FF  FF FF FF FF  FF FF FF FF
0070  00 0A 00 00  00 27 80 C1  80 C1 80 C1  80 FF FF FF
0080  FF 7F 1F BF  FF 05 05 05  00 00 00 00  00 00 00 00
0090  0A 00 00 00  00 FD FD FD  0A 95 EF 80  FF 40 46 C4
00A0  0E FF 00 00  FF 00 00 FF  00 00 80 66  06 06 03 00
00B0  00 00 00 00  00 00 2C 00  04 00 00 34  28 80 04 FF
00C0  FF FF FF FF  FF FF FF FF  FF 08 01 05  FF FF FF FF
00D0  05 05 05 05  00 00 00 00  00 00 00 00  FD FD FD FD
00E0  55 80 00 00  00 FF FF FF  FF FF FF FF  FF FF FF FF
00F0  00 00 00 00  00 00 00 00  00 00 00 00  9A FF FF FF
------[ Nuvoton ISA Sensor Device at 0A20 / Bank #1 ]------
0000  11 00 40 01  01 01 01 3C  00 64 00 64  00 FF FF FF
0010  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0020  00 01 32 3C  46 FF FF 64  8C B4 DC FF  FF FF FF FF
0030  FF 00 FF FF  00 55 00 CC  00 01 00 00  00 00 00 00
0040  FF FF FF FF  FF 00 00 FF  FF FF FF FF  FF FF 01 FF
0050  78 80 00 4B  00 50 00 FF  FF FF FF FF  FF FF FF FF
0060  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0070  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0080  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0090  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00A0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00B0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00D0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0A20 / Bank #2 ]------
0000  10 32 40 01  01 01 01 3C  00 82 00 82  00 FF FF FF
0050  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0A20 / Bank #3 ]------
0000  03 00 00 0A  0A 01 01 3C  00 7F 00 00  00 FF FF FF
0020  00 19 23 2D  37 FF FF 8C  AA C8 E6 FF  FF FF FF FF
0030  FF 00 FF FF  00 3C 00 CC  00 01 00 00  00 00 00 00
------[ Nuvoton ISA Sensor Device at 0A20 / Bank #4 ]------
0000  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0010  00 00 00 00  00 00 00 00  00 00 00 FF  FF FF FF FF
0020  FF FF FF 96  64 96 64 E1  96 04 FF FF  FF FF FF FF
0030  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0040  FF FF 03 10  FF FF FF FF  FF FF 00 00  00 00 01 FF
0050  03 73 FF FF  00 04 00 FF  FF 3C 02 13  09 FF FF FF
0060  FF 01 00 00  00 00 00 00  FF FF FF FF  FF FF FF FF
0080  23 00 D2 D2  00 00 FF D4  43 84 12 0F  FF 99 13 00
0090  32 78 C1 68  6F 20 00 2C  80 00 28 C1  C1 C1 1C FF
00A0  32 32 32 32  32 1F 64 83  00 00 00 00  00 00 00 00
00B0  FF 1F 26 0F  FF 1F FF 1F  FF 1F FF FF  FF FF FF FF
00C0  00 00 04 48  00 00 00 00  00 00 FF FF  FF FF FF FF
00D0  00 00 00 00  00 00 FF FF  FF FF FF FF  FF FF FF FF
00E0  64 83 7F FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00F0  28 40 00 00  FF FF FF FF  FF FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0A20 / Bank #5 ]------
0000  FF FF 00 00  00 06 00 FF  0F FF FF FF  FF 00 00 FF
0020  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0040  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF 01 FF
0050  D4 43 C0 FF  00 00 00 00  00 00 00 00  00 00 00 00
0060  00 00 00 00  00 00 7F 3F  3F FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0A20 / Bank #6 ]------
0000  00 00 00 00  00 00 00 FF  FF FF FF FF  FF FF FF FF
0010  FF 00 00 00  00 00 FF FF  FF FF FF FF  FF FF FF FF
0020  FF 01 02 FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0030  FF 1F 26 0F  FF 1F FF 1F  FF 1F FF 1F  FF 1F FF 1F
0040  FF 1F FF 1F  02 02 02 02  02 FF FF FF  FF FF 01 FF
0050  7F 7F 7F 7F  FF FF 00 00  04 48 00 00  00 00 00 00
------[ Nuvoton ISA Sensor Device at 0A20 / Bank #7 ]------
0000  FF 95 02 30  00 00 00 00  00 5B 5B 00  00 00 00 00
0010  00 00 00 00  00 00 00 F3  70 F8 80 F8  80 F8 80 01
0020  28 03 06 00  00 09 00 75  00 F9 00 00  00 00 00 00
0030  00 00 00 FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
   0027 0150 0250 007D 007E 0490 0491 0492 0493 0494 0495 062B 062C 062D 071C 0720
T:   49  120  255  255  255   49  120  193  105  111   32  255  255  255  128   40
T:   50  121  255  255  255   50  121  193  104  111   32  255  255  255  128   40
T:   49  121  255  255  255   49  121  193  104  111   31  255  255  255  128   39
T:   50  121  255  255  255   50  121  193  104  111   31  255  255  255  128   39
T:   50  120  255  255  255   50  120  193  104  111   32  255  255  255  128   39
T:   49  121  255  255  255   49  121  193  104  111   32  255  255  255  128   39
T:   50  120  255  255  255   50  120  193  104  111   31  255  255  255  128   39
T:   50  121  255  255  255   50  121  193  105  111   31  255  255  255  128   39
   0020 0021 0022 0023 0024 0025 0026 0480 0481 0482 0483 0484 0485 0486 0487 0488 0489 048A 048B 048C 048D 048E 048F
V:  23   00   D3   D3   00   00   FF   23   00   D3   D3   00   00   FF   D3   43   84   12   0F   FF   99   13   00   [ VID = 0.77087 V ]
V:  23   00   D3   D3   00   00   FF   23   00   D3   D3   00   00   FF   D3   43   84   12   0F   FF   99   13   00   [ VID = 0.83484 V ]
V:  23   00   D3   D3   00   00   FF   23   00   D3   D3   00   00   FF   D3   43   84   12   0F   FF   99   13   00   [ VID = 0.66077 V ]
V:  23   00   D3   D3   00   00   FF   23   00   D3   D3   00   00   FF   D3   43   84   12   0F   FF   99   13   00   [ VID = 0.66248 V ]
V:  23   00   D3   D2   00   00   FF   23   00   D3   D2   00   00   FF   D4   43   84   12   0F   FF   99   13   00   [ VID = 0.66736 V ]
V:  23   00   D3   D3   00   00   FF   23   00   D3   D3   00   00   FF   D4   43   84   12   0F   FF   99   13   00   [ VID = 0.66248 V ]
_TZ_.THM0._TMP             :
_TZ_.THM1._TMP             :
_TZ_.THR0._TMP             :
_TZ_.THR1._TMP             :
_TZ_.TZ00._TMP             :
_TZ_.TZ01._TMP             :
_TZ_.RTMP                  :
_TZ_.RFAN                  :
_TZ_.RFAN(0)               :
_TZ_.RFAN(1)               :
_SB_.ATKD._HID             :
_SB_.ATKD.TMPR             :
_SB_.PCI0.LPC0.EC0_.CCTV   :
_SB_.PCI0.LPC0.EC0_.LRPM   :
_SB_.PCI0.LPC0.EC0_.HRPM   :
_SB_.PCI0.SBRG.EC0_.ECPU   :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0   :
_SB_.PCI0.SBRG.EC0_.TAH1   :
_SB_.PCI0.SBRG.EC0_.ST00   :
_SB_.PCI0.SBRG.EC0_.SC01   :
_SB_.PCI0.SBRG.EC0_.SC02   :
_SB_.PCI0.SBRG.EC0_.SC03   :
_SB_.PCI0.SBRG.EC0_.SC04   :
_SB_.PCI0.SBRG.EC0_.SC05   :
_SB_.PCI0.SBRG.EC0_.SC06   :
_SB_.PCI0.SBRG.EC0_.TH0R   :
_SB_.PCI0.SBRG.EC0_.TH1R   :
_SB_.PCI0.SBRG.EC0_.F0TS   :
_SB_.PCI0.SBRG.EC0_.F1TS   :
_SB_.PCI0.PIB_.EC0_.TCRT   :
_SB_.PCI0.SBRG.EC0_.CTPM   :
_SB_.PCI0.SBRG.EC__.CPUT   :
_SB_.PCI0.SBRG.EC__.SYST   :
_SB_.PCI0.LPC_.EC0_.CTMP   :
_SB_.PCI0.LPCB.EC0_.CTMP   :
_SB_.PCI0.LPC_.EC0_.TMP1   :
_SB_.PCI0.LPC_.EC0_.TMP2   :
_SB_.PCI0.LPC_.EC0_.TMPI   :
_SB_.PCI0.LPC_.EC0_.TMPV   :
_SB_.PCI0.LPCB.EC0_.A1TP   :
_SB_.PCI0.LPCB.EC0_.A2TP   :
_SB_.PCI0.LPCB.EC0_.FAN0   :
_SB_.PCI0.LPCB.EC__.TS1R   :
_SB_.PCI0.LPCB.EC__.TS2R   :
_SB_.PCI0.LPCB.EC__.TS3R   :
_SB_.PCI0.LPCB.EC__.F1FL   :
_SB_.PCI0.LPCB.EC__.F1FH   :
_SB_.PCI0.LPCB.EC__.F2FL   :
_SB_.PCI0.LPCB.EC__.F2FH   :
_SB_.PCI0.LPC_.H8EC.RTMP   :
_SB_.PCI0.LPC_.H8EC.LTMP   :
_SB_.PCI0.LPC_.H8EC.MTMP   :
_SB_.PCI0.LPC_.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.CTMP   :
_SB_.PCI0.LPCB.H8EC.DTMP   :
_SB_.PCI0.LPCB.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.ITMP   :
_SB_.PCI0.LPCB.H8EC.MTMP   :
_SB_.PCI0.LPCB.H8EC.STMP   :
_SB_.PCI0.LPCB.H8EC.PFAN   :
_SB_.PCI0.LPCB.EC0_.OTPC   :
_SB_.PCI0.LPCB.EC0_.VGAT   :
_SB_.PCI0.LPCB.EC0_.CHPT   :
_SB_.PCI0.LPCB.EC0_.CPUT   :
_SB_.PCI0.LPCB.EC0_.SYST   :
_SB_.PCI0.LPCB.EC0_.DTS1   :
_SB_.PCI0.LPCB.EC0_.DTS2   :
_SB_.PCI0.LPCB.EC0_.DIMM   :
_SB_.PCI0.LPCB.EC0_.FANH   :
_SB_.PCI0.LPCB.EC0_.FANL   :
_SB_.PCI0.LPCB.EC0_.CUTP   :
_SB_.PCI0.LPCB.EC0_.PHTP   :
_SB_.PCI0.LPCB.EC0_.DIMT   :
_SB_.PCI0.LPCB.EC0_.INLE   :
_SB_.PCI0.LPCB.EC0_.PANT   :
_SB_.PCI0.LPCB.EC0_.F0RM   :
_SB_.PCI0.LPCB.EC0_.F0DT   :
_SB_.PCI0.LPCB.EC0_.F1RM   :
_SB_.PCI0.LPCB.EC0_.F1DT   :
_SB_.PCI0.SBRG.EC0_.CUTP   :
_SB_.PCI0.SBRG.EC0_.PHTP   :
_SB_.PCI0.SBRG.EC0_.DIMT   :
_SB_.PCI0.SBRG.EC0_.INLE   :
_SB_.PCI0.SBRG.EC0_.PANT   :
_SB_.PCI0.SBRG.EC0_.F0RM   :
_SB_.PCI0.SBRG.EC0_.F0DT   :
_SB_.PCI0.SBRG.EC0_.F1RM   :
_SB_.PCI0.SBRG.EC0_.F1DT   :
_SB_.SAMB.TMPC             :
_SB_.SAMB.TMPH             :
_SB_.STR0._TMP             :
_SB_.STR1._TMP             :
_SB_.STR2._TMP             :
_SB_.STR3._TMP             :
_SB_.STR4._TMP             :
_SB_.STR5._TMP             :
_SB_.STR6._TMP             :
_SB_.STR7._TMP             :
CPUT                       : <TYPE>0</TYPE><LEN>4</LEN><DATA>0</DATA>
GPUT                       :
SYST                       :
FANT                       :
BATT                       :
  • Fiery changed the title to A problem with AIDA64 sensors causing the system to freeze (Jginyue X99M-Plus V2)
will you be able to fix this problem?)
Let me know how it works.
good day, I checked the program and I want to say thank you so much!!! the system is no longer freeze and the program can be safely left on auto start. thank you very much again!
Thank you for your feedback!
  • Fiery changed the title to fixed: A problem with AIDA64 sensors causing the system to freeze (Jginyue X99M-Plus V2)
