HyperFirez Posted July 16, 2022 Posted July 16, 2022 Hi there, as the title suggests, my sensor panel has entirely stopped showing up once I updated the application to the newest version. I've tried using the Rest Position button in the Preferences but to no avail. Any ideas? Thanks. Quote
JayWhy Posted July 17, 2022 Posted July 17, 2022 I am having the same issue. Sensor Panel and OSD both not showing after the update. Tried resetting position, closing program in task manager, restarting pc, etc. Quote
Fiery Posted July 17, 2022 Posted July 17, 2022 On 7/16/2022 at 8:58 AM, HyperFirez said: Hi there, as the title suggests, my sensor panel has entirely stopped showing up once I updated the application to the newest version. I've tried using the Rest Position button in the Preferences but to no avail. Any ideas? Thanks. Try to restart Windows, and check it again. Quote
JayWhy Posted July 18, 2022 Posted July 18, 2022 I have done a full shut down and it is not working. When I go to Computer>Sensor it just gets stuck on the "Detecting sensor information..." loading bar. Going into Preferences>OSD>OSD Items I have the same issue. All of my system information is displaying correctly but it seems that it cannot find any sensor information now. Quote
JayWhy Posted July 22, 2022 Posted July 22, 2022 Update: I figured out that my issue was not caused by the latest update. It seems SignalRGB interferes with AIDA64 pulling sensor information. I will have to have a play around with settings and see if I can get both working together. Quote
