Rotate AX206 LCD Display
BreezierSix
On 8/7/2022 at 1:17 PM, BreezierSix said:
Does anyone know how to rotate screen on  AX206 LCD Display?
We've implemented rotation for AX206 LCD in the latest beta version of AIDA64 Extreme available at:
  • 3 months later...
Hallo @Fiery (and sorry for the ping).
I have noticed that when you select the option to rotate the result is that all the screens rotate at the same time, the interesting thing would be to be able to rotate them individually.
Well, rotating them 90º doesn't work (as posted above) but 180 degrees works well and it would be great, at least, to be able to manage it individually on each screen.
Thank you!
On 8/31/2022 at 10:39 PM, alesmart said:
Hello, I'm using display AX206 LCD, I downloaded the latest version of AIDA64, but display rotation does not work correctly.
Same Issue for me, can`t rotate them with the Software which is supposed to do so. Another Solution would be to get the Ability to Rotate the Sensor Data Counters.
I have the same problem, this is the screen:
Device properties
Device Class DC / A0 (Diagnostic Device)
Peripheral description USB-Display
Device ID 1908-0102
Serial number 20201115
USB Display product
Manufacturer QTKeJi.Ltd
Device protocol B0
Revision 0100h
Current speed Full (USB 1.1)
Supported USB version 1.10
@BreezierSix @alesmart @bibibig73  @Wendi  @Vigges66 K
We've fixed the AX206 rotation issue in the latest beta version of AIDA64 Extreme available at:
Thanks, problem solved for me!
